Where/How do I find the codec(s) that I'm using to capture? Are they listed in a folder?
What do you use to capture? Codecs are usually in the System32 folder.
Hello. -
I'm using a DAC-100 by datavideo. I'll check the SYSTEM32 folder but don't know if I'll be able to tell what's what... thanks.
I thought the DAC-100 is like the ADVC-100, and captures to DV with a hardware codec....
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
DV CODEC for VHS Capture?
By enbidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 140Last Post: 24th Feb 2011, 21:11 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 01:27 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 14:53 -
The Best Capture Codec to reduce artifacts is???
By maxtrack in forum Capturing and VCRReplies: 5Last Post: 27th Jul 2007, 16:47 -
Video Capture Codec
By ThatOtherGuy in forum Capturing and VCRReplies: 17Last Post: 2nd Jul 2007, 03:18
