I am capturing VHS movies on Scenalyzer Live at a resolution of 720x480 in DV format. i checked this in mediaplayer and it says 720x480.
When I import the movie into TMPGEnc, it will auto detect it as "4:3 525 line (NTSC, 704x480)".
I noticed that there are two choices in TMPGEnc for me to choose from: "4:3 525 line (NTSC, 704x480)", and ""4:3 525 line (NTSC)". Should I stay with the auto detected resolution (is this normal?) or should I switch it to the other setting?
Thanks for the help.
Results 1 to 11 of 11
Even DVD rips that I've put into TMPGEnc report a 704x480 resolution. They always turn out fine. It might just be a typo in the program.
It only really matters in the encoding process anyway. If you choose "Full Frame", it'll make it that, whatever aspect you specify, if it's 4x3 then that's what it'll make it. I'm sure you'd want to crop out the bad edges from your VHS while encoding anyway."I think I know exactly what I mean, when I say it's a Shpadoinkle day!" -
Not sure about the difference between the too. I have notices that but from tests it is better to stick to the format the software proposes as default.
Not to steal a thread ... but i will
Does anyone here have trouble using DV with TMPGEnc ??
when i go to open/import a DV file it started the scanning process and ALWAYS hangs doing that
the files have a DVSD fourCC code, this is right huh ??AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb -
If your input file is 720x480 then you should choose the option that says "4:3 525 line (NTSC)" and not the "default" setting of 704x480
The 704x480 setting resizes the 720x480 to 704x480 by squishing the video (though the effect is very slight) and then adds 8 pixels of black on either side.
Follow this link to explain it all bro......goodluck
http://www.digvid.info/tmpgenc/settings_advanced.php
If your video is 4:3 or anamorphic 16:9 use the 4:3 setting rather than broadcast specific sizes as these sometimes alter the picture geometry slightly.
DaveQB,
You might be running into the problem of TMP needing DV2 format not DV1. Look in tools for the DV1 to DV2 converter. It's a canopus file coverter. Then it should import no problem. You can also use gspot to open your DV file and it should tell you it's like Mpeg1 DV1 format. -
, I thought this question was dead already. I am glad I looked at it again.
Thanks a lot FulciLives, Since you mentioned it, I do see the little black lines on either side now when viewing on the PC. The television cuts the edges off so I cannot see them on the TV.
You too compaqsport, much appreciated!
Questions about interlacing/deinterlacing - TMPGenc users
By yukon33 in forum Newbie / General discussionsReplies: 9Last Post: 25th Jun 2010, 13:41 -
DVDfab users - Question about PathPlayer
By jason in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2009, 15:00 -
TMPGEnc 3 - Quick Menu Question
By heyjjjaded in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2008, 14:05 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13
