I am burning DVD-VCD's. When I burn my VCD files to a normal VCD using Nero the quality is great. When I author and burn my DVD-VCD's with the exact same files using TMPGEnc DVD Author (this program reencodes the VCD audio for me while it is in the "output" process), the final video quality of the DVD is less than that of the VCD. Is it normal to lose some quality when going through the authoring process? It's like there is a slight flicker on the screen. I can get used to it after awhile and it's not to bad, but when I switch between the normal VCD and the DVD-VCD the difference is very notable. I thought that my DVD-VCD would have just the same quality as my regular VCD.
I am burning black and white TV shows captured with my ATI All In Wonder Radeon card as well as ATI's MMC 7.7. I capture directly to VCD MPG format. This whole capturing part can't be it though because the VCD's from these files are fine...I've narrowed it down to the authoring part. Now I just don't know what to do.
Any Suggestions?
-Eric
According to TMPGEnc DVD Author's help file:
It is necessary to convert the format to MPEG-1/2 format based on the DVD video standard. This function, however, is not available in this software. To change the AVI file into an MPEG-1/2 file based on the DVD video standard, we recommend using our company's MPEG-1/2 encoder TMPGEnc Plus.
Author can not encode video. It does not change your video files other than creating VOB files. That's not considered a reencode.
I'm not sure what's happening with your DVDs but it may be something pretty simple. Maybe it's the quality of your blank disks? I don't see what the program could be doing to your files.
Have you tried another authorizing application? There are several offered for free trial download. You could try some of them, but DVD Author is the best program I've ever used.
Good luck.
Maybe consider cleaning your DVD drives. The settop box and your burner. Lint and dust can do that too, but I would suspect my media.
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 06:42 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
ConvertXtoDVD vs. Tmpgenc DVD Author w/Divx Authoring
By Iron_Monkey in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 21:00 -
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 21:36 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15
