  1. I understand I need to convert to Mpeg2, although Studio seems to be able to use AVI files as well, to author DVD's. How do I convert the RM's?
    DoctorJ
  2. There are a ton of guides on the menu on to the left. I think you'll find what your looking for under "convert".
  3. i would use eo video to convert the rm file to avi and then convert the avi file to mpeg using tmpgenc. it works cos i do this all the time.
  4. yeap
    EO Video All the way
    (you can also try TINRA too)
    https://www.videohelp.com/forum/viewtopic.php?p=695877#695877
    good luck
    Increase knowledge, increase sorrow.
