It keeps doing this throught to whole movie. What could be causing this?
Macrovision. If the DVD is protected by macrovision you can run the cable from the DVD player into the TV and everything will look fine. But if you run the cable from the DVD player to a video recorder and then to TV you will see the brightening/darkening effect you describe. You would also get this if you copied a macrovision protected video tape.
Macrovision tricks the automatic gain control circuitry in your vcr into alternately brightening and darkening the signal. -
TV VCR combo TVs often still contain macrovision protection. But make sure that you are not running your DVD player through a VCR or any other recording devices.
And a correction, macrovision doesn't trick anything, devices have to be programed to react to macrovision.
Not true. VCRs appeared before Macrovision and they are disturbed by it.devices have to be programed to react to macrovision.
Macrovision exploits the normal behavior of video AGC circuits and
sync detection circuits -
Thanks guys. That's exactly how I have my dvd player setup! I'll connect it directly to the TV as soon as I go to radio shack. (I have an "F" type connection)
SOLVED: Media Player Classic - playback picture too dark......
By bahjan in forum Software PlayingReplies: 0Last Post: 17th Nov 2010, 06:32 -
HDV Picture is too dark.
By dj_magic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jun 2008, 15:21 -
DVD Slideshow GUI - Too light on TV screen
By chrishallowell in forum EditingReplies: 0Last Post: 14th Sep 2007, 13:42 -
How to improve dark VHS picture?
By rbatty11 in forum RestorationReplies: 15Last Post: 11th Sep 2007, 19:57 -
Dark picture
By MarioB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2007, 00:14
