NeroVision seemed to cut films (for discarding bad footage) nicely but when I burned the DVD I ended up with a static image at some point and the original soundtrack playing in the background.
Too bad only Premier razor's tool does what I need the way I needed.
I do not understand Ulead (and others) way of cutting out bad footage and the jog bar behaviour is a mystery to me. I do not only want to trim at the extremes but discard bad fotage at any point.
The razor does what most people need: cut here, cut there, and click in the middle, press DEL key and voila I get rid of bad footage.
Results 1 to 1 of 1
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 09:49 -
Simple AVCHD multi trim?
By Mike82 in forum EditingReplies: 1Last Post: 5th Jul 2009, 10:13 -
simple editing program
By devdev in forum EditingReplies: 6Last Post: 4th Jun 2009, 08:40 -
Simple DVD to FLV program...?
By vividbreeze in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2008, 15:20 -
Simple free program editing.
By Traveller in forum EditingReplies: 12Last Post: 24th Oct 2007, 01:42
