This DVD was made from a Cam recorder and transferred to a DVD video recorder.
The size of the DVD is 3.16 gb but the largest file is only 1.048 gb. I can only see one titel, but there should be 3 titles on the DVD.
The DVD is has two directories VIDEO_RM and Video_TS. In VIDEO_TS are two two .VOB files. The first is only 36k, I assume that this is the title, the second VTS_01_1.VOB is 1.048 gb.
I used PowerDVD and Win DVD as a player. I tried several DVD players. On the DVD videorecoder the titles are there.
I also loaded an ASPI driver. I tried with a UDF file system. Now I run out of ideas. The data is on the DVD, but how can I get to the data in order to copy, it onto the disk.
Its a recording of our last sailing trip and the crew would like to have personal copy.
use dvddecrypter to rip the dvd onto your hard drive, either in file mode or ISO mode (file mode to get at the VOBs or ISO if you just want the whole image on your PC).
Not sure what you want to do with it once it's on your PC..do you have a DVD burner? Are you trying to get only some of the individual titles?"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
DVD Recoder
By AngusYoung67 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 18th Mar 2011, 15:57 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
Help Liteon DVD recoder
By killingme in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Apr 2009, 18:46 -
How record a streaming webcast off my MAC & onto a DVD Recoder HD??
By atomboy in forum MacReplies: 5Last Post: 3rd Apr 2009, 10:48 -
Does anybody have a LG DR787T DVD recoder? if so.....
By simplesmn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Dec 2007, 10:48
