How can I take a MPG2 file and make it so it plays in my DVD player that is connected to my tv?
Hi Corry,
Simple enough question, but very difficult to answer.
If the MPEG2 file is compliant, then simply author and burn it onto a disk. If its not compliant, then re-encode it so it is compliant, then do the above.
Is your MPEG file compliant? You can use AVIcodec (a free download) to find out what you have there.
A nice encoding program is TMPGEnc, and good authorizing program is TMPGEnc DVD Author.
We'll need a tad bit more info. ok
Good luck.
Advice for best DVD MPG2 Muxer
By Krelmaneck in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 05:51 -
editing mpg2 to dvd without quality loss
By dailM in forum EditingReplies: 2Last Post: 8th Aug 2009, 02:35 -
MKV -> MPG2 for HD-DVD Authoring
By Mickey79 in forum Video ConversionReplies: 18Last Post: 13th Feb 2008, 09:38 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 10:36 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 05:59
