I burned a dvd-r and it works on my computer DVD but not on my xbox dvd. Why?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Do any DVD-R work in your X-Box? Playing in you computer means nothing, you can do everything wrong and it will still play. Whether or not it plays in a settop player is the key.
It can be:
1) Bad media, you XBox is picky about media
2) Bad Burn
3) Bad files (you didn't do it right)
4) Nothing, you XBox simply doesn't do DVD-R'sTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
Try this
Use Nero, don't use the wizard, choose DVD-ROM (UDF/ISO), in the UDF tab check "Force DVD-Video compatibility mode for XBOX", create VIDEO_TS and AUDIO_TS folders, proceed as usual. -
XBOX uses a different type of ISO format - if you do google on xbox iso you should find your answer..
I use TDK DVD+R and DVD+RW and I burn in DVD-VIDEO mode using Nero 6 and everything always works in my XBOX. Sometimes the +RW isn't recognized the first time I put it in, but if I eject it and then put it back in, it's fine.
dj matty b -
I've been reading Sentinel DVD-Rs, Primedisc DVD-Rs and some very bad Sky DVD-Rs in my XBOX with no problems at all.
I just burn using Nero 5.5 and thats it. I had no need to use Nero's Force DVD-Video compatibility mode for XBOX since every copy I made using Nero's standard wizard were XBOX readable.
DVD -> PC -> Xbox + 5.1
By Tony Jenkins in forum Media Center PC / MediaCentersReplies: 3Last Post: 11th Apr 2011, 08:18 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Copying DVD to PC then Streaming to XBox
By 200thhorseman in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2009, 15:03 -
Burning A DVD-R For XBOX 360
By alaskajoe in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2007, 16:14
