I have succesfully edited/archived many home videos to DVD using Studio 8. I want to get the video "back" into studio to create a different type of home video.
I have read many pages of posts/guides regarding tmpegnc and dvd2avi, but I am really confused with what will suit my needs.
My Goal: DVD homevideo back to an AVI file for studio 8 to edit with no quality loss.
Thanks for your help! Happy New Year!
you would follow the same steps that anyone wanting to edit commercial DVD video would follow - rip the video, demux to elementary streams, remux it into an mpeg file, convert that mpeg to avi to edit, reencode, etc. check the guides.
if you just want to do cut editing, you can try Chopper XP and cut the vob files directly - no reencoding or demuxing necessary.
but for more involved editing (like putting a fade rather than a cut transition, or adding titles, effects, etc.) you will need to convert to a video format your editing software can handle.
as for quality, you may take a bit of a hit because you will most likely have to go from mpeg-2 to avi and back to mpeg-2.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks for your reply. I want to do more than cut editing but I'm still confused on the process...Would you fill in the gaps...
1)Rip DVD to HD using DVD Decryptor
2) Convert to avi using what????
also...what do you mean by elementary streams, demux, and remux
3)Edit/Burn new avi file to dvd using Studio 8
Sorry for the "basic" sounding questions, but thanks for the patience. -
"elementary streams" refers to separate streams of audio data and video data.
"demux" is short for demultiplex - it means you take a multiplexed stream (such as an MPEG-2 file) and split it into an audio stream and a video stream.
"remux" would be to put them back together.
so you rip a dvd - you end up with a bunch of VOB files. a VOB is basically an mpeg-2 file with some other info wrapped around it, like chapter information, extra audio streams, etc. You can use DVD Decrypter or SmartRipper to extract the elementary audio and video streams from the VOB file.
you will end up with a .m2v file (the video stream) and an .ac3 or .mp2 or .wav (the audio portion).
depending on the editing you want to do, you will probably want to remux these files into an mpeg-2 file that has audio and video, and then convert that file into an avi for editing. you may want to use TMPGenc to convert your mp2 file to a wav, or BeSweet to convert your ac3 file to a wav, before remuxing. (some of the editing software will not load an mp2 or ac3 file - like mpeg, they are more suited to final delivery of data, rather than editing).
there is a modified version of Virtualdub that can load mpeg files, and with that you should be able to convert to an avi with a low-compression codec for editing. Check the Tools section at left. While you are surfing the site, check the Guides as well, especially those in the How To: Convert section.
hope this helps.- housepig
Housepig Records
out now:
to do simple fades to a VOB file...would you have to demux it & convert it to avi? i thought I might be able to pull the fades off without losing quality....I hope so atleast.
Choppy/ out of sync audio from homevideo to DVD
By dwilson in forum Authoring (DVD)Replies: 1Last Post: 11th Mar 2009, 23:53 -
Archived unfinalized DVD-RWs--can i play them?
By mpmp0 in forum Newbie / General discussionsReplies: 23Last Post: 30th Aug 2008, 23:31 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13 -
Advice please for newbie on processing/editing DVD archived TV programmes
By iansport in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jun 2008, 06:16 -
Making a homevideo more like a theater movie
By qazwsx16 in forum EditingReplies: 12Last Post: 4th Jun 2007, 14:56
