Followed chickenmans excellent dvd to dvdr tutorial which was perfect for me apart from a minor detail. I authored the dvd with maestro which played perfectly on my standalone. The only thing was when the movie finished it started to play again from the beginning whereas i would have liked it to stop completely. I'm sure this could be done with maestro but i dont know how to do it. Any help would be great.
It's defined in Connections window, in the line :
Movie x: Chapter y (last one): End Action
If you let this field blank your dvd should stop at the end of the last chapter (I personnaly set it to go back to main menu) -
Milo, to get it to go back to main menu do you right click in the target space adjacent to the last chapter point and select menu? Thanx for your help mate.
Exactly : Line "last Chapter: End Action" right-click in "Target" field and select "menus" then choose which menu / button
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 20:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
