Just got a dvd +- burner (Yes i know its dash, not Minus) and i was interested in storing 4.37gb of regular data (divx movies, mp3s, game rips, pictures) onto a dvd-r, just like you would a regular cdr with a bunch of stuff on it. I checked the really really long faq and looked around here and still cant find out how.
Also another question too, (if cant be answered ill just post it by itself) Can i burn multiple cd images like .bin and .cue onto dvdr? Like say for example i want to burn the new lotr movie, its 4cd images. Can i do it onto a dvdr or should i just use cdr?
Oh, and if i burn the .bin and .cue onto a dvdr, will it be able to be played on my apex dvd player? (i know it wont be dvd format obviously because of the fact thats its just an .mpeg file inside a few folders and dvd is .VOB files)
Oh, I have nero 6.3.0.0 and a few other mainstream burning apps. Just if its possible to make regular data dvdr in nero would be good and how to do it.
When using a burn program like Nero, you select DVD data disk, rather than a video disk.Originally Posted by Moloko_Plus
Only as pure data, I believe. Regardless, they will not play in your player.Also another question too, (if cant be answered ill just post it by itself) Can i burn multiple cd images like .bin and .cue onto dvdr? Like say for example i want to burn the new lotr movie, its 4cd images. Can i do it onto a dvdr or should i just use cdr? Oh, and if i burn the .bin and .cue onto a dvdr, will it be able to be played on my apex dvd player? (i know it wont be dvd format obviously because of the fact thats its just an .mpeg file inside a few folders and dvd is .VOB files)
Bring up the wizard, select Data DVD, follow the prompts, and a blank directory will appear. Drag and drop your files normally. Select the burn icon, and folow the prompts.[/url]Oh, I have nero 6.3.0.0 and a few other mainstream burning apps. Just if its possible to make regular data dvdr in nero would be good and how to do it.Hello. -
I dont see "Data DVD" under nero..I only see "Mini DVD", and there is no wizard, is there? I thought it was only on nero 5..
Yeah, under "New" the compilation i dont see "Data DVD" at all =/
Do you have nero 6 or nero 5? (If you have nero 5 and you know it works, ill go back to nero 5, i have a backup of 5.5.10.54 on my harddrive not installed and have been looking for an excuse to go back to it)
Oh forgot to mention: MERRY CHRISTMAS ALL (sorry..im not much for the holiday seasons) -
Sorry, I do have version 5. never saw a reason to update.
Hello. -
No you cant burn cdr images (bin/cue) to a dvd. better to keep them as cdr or extract the mpg, concatenate them convert them to an accepatble dvd format (1/2d1?) then author them and burn to a dvd-video. Burn to a dvd exactly as you would burn to a Cdr. Nero5.5 will burn to dvd unless you have a drive locked version..( it will only recognize the drive it was shipped with)..
Ohhh hey, i found out now. I didnt have my dvd drive selected..Duh. Thanks for putting up with me
Ill let you all know if i have any more questions.
-Chris
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 04:10 -
Question about IMAX footage being cropped for regular theatre screens
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jul 2008, 16:01 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 17:00 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 06:53 -
How Do I Burn A DVD Data Disc ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 13:15
