    Nov 2003
    Already transcoded the dvd with Dvd Decrypter and then Dvd2One and using RecordNow Max to burn..
    Everything is working great but when am about to play the dvd in a recorder it opens with the files i have on the record !
    It should start direcly with the movie i thougt ?
    So what am i missing here..
    Could someone please help me..
    vapea
    May 2003
    canada
    Just a guess.
    The dvd2one files MUST be in a folder called VIDEO_TS.
    This folder MUST be upper case.
    This is what you you add to the data input on recordnowmax.
    Not just the files that dvd2one created.
    To increase compatibility among players you can also add an AUDIO_TS
    folder. This folder is empty.
    Your software:
    dvd decrypter
    dvd2one
    recordnowmax
    Is a great combination. I use it all the time with success.
    I hope that this is the solution to your.
    Kiki
  3. vapea
    Are you trying to play the DVD with your computer, or a set top DVD player and your TV set? I didn't quite follow. ok
    Good luck.
    Nov 2003
    Thanks !
    I didnt have a VIDEO_TS to burn, only used all the files !
    Thats was the problem !!
    Thanks again..
    By the way, someone who know what i should sett the recording-options
    on i RecordNow Max ?
    Under Data Job Options in the Dvd choises
    Somewhere i read that it should say:
    "UDF with Joliet-Up to 106 in length, any chair ..... And somewhere else it said the other option with ... 128 ...
    What is the correct option ?
    I know that the option above it should say:
    Track at Once (TAO), Closed
    vapea
  5. "By the way, someone who know what i should sett the recording-options
    on i RecordNow Max ?"
    www.dvdrhelp.com/forum/viewtopic.php?t=195513&highlight=
    Nov 2003
    Thanks !
    I needed that !
    // Merry Christmas !
    vapea
    Nov 2003
    Oh, buy the way..
    Do you have to have one VIDEO_TS and one AUDIO_TS ?
    I only used VIDEO_TS and the worked in my TV-DVD, whats
    the differens ?
    vapea
  8. Originally Posted by vapea
    Oh, buy the way..
    the differens ?
    I add the AUDIO_TS folder to be DVD compliant,some players are picky.
