I just installed a 160gb hard drive and it came with a ATA/133 PCI card. I hooked it up using the PCI card and I was just wondering if there is any difference in using a PCI card or not? (I do have Windows XP SP1)
Also does anyone know what the difference is with RDRAM that has 8 device channels and one that has 4?
There shouldn't be any difference in using the PCI card.
Can't help you with your next question though, sorry. -
If you where not to use the IDE PCI card you must make sure that your computer supports 48-bit adressing (HDs over 137gb). This would be a feature of your motherboard. If your PC doesnt support 48bit adressing there is a possiblty that the PC will run the HD but you will most definity run into problems further down the road, such as data lost and all kinda of unfun stuff like that.Originally Posted by FernE97
Archiving old 8mm video to Hard Drive questions
By flyingsolo in forum Newbie / General discussionsReplies: 5Last Post: 13th Sep 2011, 18:15 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Fat32/NTFS External Hard Drive Formatting Questions.
By bbanderic in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2010, 22:13 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32
