i just got a sylvania SSD803 DVD/VHS combination for Christmas. In the manual it says that it will not play Video CDs. does this mean it wont play any SVCDs as well? is there anyway i can bypass that? if not are there any formats that i can convert my files to that will play on the DVD player? thanks in advance
Burn standard DVD compliant disks with VCD MPEG1 files on it. This will work with TMPGenc DVD Author and other authorizing programs.
If you've got VCD CDs now, then you'll need to convert DAT to MPEG1, then reauthor these files to DVD. That will work.
If you've got SVCD CDs now, then you will need to convert and reencode to either 352x480, 720x480, or 352x240. SVCD 480x480 aren't DVD compliant and won't work on DVDs.
Good luck. -
Well not exactly,you need to convert the audio to 48khz,there is a good conversion guide in the "How To" section using freeware tools(IsoBuster,TMPGEnc & IFOEdit).If you want to put multiple VCD's on one DVDR then I recommend Ulead DVD MovieFactory it will convert,make menus and burn.Originally Posted by littledg
i just tried burning and when i hit burn on nero, it tells me i have the wrong type of DVD, is there anyway that i can burn to a DVD-RAM? this way i can take files off the DVD and put new ones on as i dont want these files on an expensive disk like that forever
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
