I have some home videos i would like to transfer to dvd. I am familiar with dvd burning but not with transfering video to dvd. What will i need to put the video onto the computer. Is any freeware available?
You need to
- capture your video : https://www.videohelp.com/capture
- edit it: https://www.videohelp.com/edit
- convert it: https://www.videohelp.com/convert
- author it: https://www.videohelp.com/author
and you're ready to burni it. Easier said than done. The good news it that this site is a gold mine of great info. I suggest you read a lot to learn and eventually ask questions when you are stuck.
Good reading. -
Audio/Video Composite and-or S/Video and I recommend you get some very good ones. Radio Shack has some real nice Gold end - heavy shielded - and filtered cables. Their not cheap, but you're going to need them.
Don't use coax inputs unless you have no other choice. You will loose alot of quality even with high performance coax cables.
Get the best, you won't be sorry.
Good luck. -
OR....
Go out and buy yourself a cheap DVD Recorder at the after Christmas sales. Doubt you will find a decent(77 or 80) Philips one.... but the "lesser name" ones are sometimes more reliable and a whole lot cheaper.....less headaches too than with capturing....ALOT less.
help with burning home videos to dvd
By ppalacios2 in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2010, 07:17 -
new to making home videos, canburn to DVD but NOT as one movie ! ??
By DoktorDave06 in forum Newbie / General discussionsReplies: 9Last Post: 10th Feb 2009, 14:25 -
Does Philips DVP 5990 play home burnt double layer DVD videos?
By indyram in forum DVD & Blu-ray PlayersReplies: 13Last Post: 28th Dec 2008, 11:06 -
Recent home videos (VHS) recorded to DVD & now in Mpeg2...
By tehfreeman in forum DVD RippingReplies: 7Last Post: 19th Dec 2008, 14:12 -
Home Videos DVD - Changing Menus
By FBI Agent in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2007, 22:16
