Is there any good programs that let you create your own DVD menus?
https://www.videohelp.com/author
How about some reading of the great tools and guides of this site? -
TMPGenc DVD Author is a good one. Just download the program (free trial) and read through the help files in the program. Pretty neat. You'll like it.
Don't get me wrong, I love TMPGEnc DVD Author, but the menu function is extremely restrictive. If you're just looking to do basic menus and don't mind using a cookie cutter template, it's fine. I've heard that DVD Lab gives you a little better control over menu creation.
You have the ability to create and edit your own menu templates and even have motion menus if you like. There are several options for menu generations and if a person snoops around in the program they are easy to create. They can be made pretty custom if you like.
When one considers all the options available in that program, you haft to admit it's probably the best available.
DVD Shrink-like programs
By technicolornightmare in forum Newbie / General discussionsReplies: 9Last Post: 23rd Oct 2010, 09:45 -
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Dvd programs for windows 7
By tansdad in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2010, 16:39 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
question about different OCR (optical character recogni) programs
By jimdagys in forum SubtitleReplies: 3Last Post: 19th Dec 2007, 18:31
