I have burnt disk for over a year never had any problems at all to recently.
First I got problem with those verbatim disk, they seems to burn just fine with dvd decryper but didn't load in either my computer dvdor my two standalone players. Now I got similar problems with two Philips cmc disks. They was burnt without problems, but didn't load in my computer or standalon players. I have discovered that the disks that fail to play don't look the way they should. The written dye look strange it's almost like an inner circel of the dvd not has been written,( vary from 10-50% of the dye) It's a bit hard to explain, but haven't seen this on any disk before.
I don't know if it has something to do with my burner(Philips 228), but Ritek, Neo Premium(Ricohjpnr) and Verbatim 2,4x(MCC) still works great. This is starting to be very frustrating doing 5 coasters in a week, when not been doing a singel one in over a year!
If other brands of disk are working fine then it points to the media rather than your burner. Sounds like a bad batch of disk.
Not bothered by small problems...
Spend a night alone with a mosquito -
I have had some similar problems when writing at 4x. If I burn the same 4x media at 1x or 2x they work fine.
Are you running the latest firmware on that Philips burner? Because earlier firmware versions will not write to 4x media without errors.
Originally Posted by Espen
And yeah writing to 4x disc with your burner requires 1.51 or later firmware (as -jsl- said)
Oki, well I thought the Firmware could be the problem, but I burnt like 15 riteks 4x without problem. However I try to upgrade the Firmware right now, but it seems to be some problems. Flash tool can't find any target drive to upgrade. Is there another way to upgrade the Firmware?
Strange Audio Problems?
By Ownaholic in forum EditingReplies: 2Last Post: 17th Jan 2012, 17:21 -
Change video, keep audio without re-encode ? Problems with strange AC3.....
By Gwar in forum EditingReplies: 18Last Post: 27th Aug 2011, 08:19 -
Strange microphone problems
By alintatoc in forum ComputerReplies: 4Last Post: 9th Oct 2009, 16:16 -
strange DVD problems
By mikehende in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2009, 16:43 -
Strange problems with video corruption
By boulder in forum Software PlayingReplies: 0Last Post: 27th Sep 2008, 12:19
