Hi, I make a backup of a dvd-9 and I burned it. When I went to play it on my player, I get no audio. I press the audio button on the remote and I see all the available audio on the screen but I still can't hear anything. Never had this problem before except now that I tried DVD Shrink 3. Any suggestions?
Which audio stream did you choose? If you selected an AC3 audio stream and you don't have a decoder there might not be any sound. I am not sure that this is the case but its worth a try.
How do you edit VOB files from DVDShrink to mute same audio portions?
By soundoff in forum Newbie / General discussionsReplies: 3Last Post: 11th Mar 2012, 19:58 -
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 7th Dec 2009, 23:06 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
DVDShrink - Multiple audio tracks? What's what?
By kelemvor in forum DVD RippingReplies: 17Last Post: 16th Jul 2007, 11:07
