Hi there,
I just bought a DVD Writer (Pioneer DVR-106) and got my first DVD backup with CloneDVD. I notice that quality meter still remains the same, even if I remove Audio and/or Subtitle stream. Is this a bug ? Do the movie will be transcoded at better quality if I remove them, even if the meter doesn't update itself ? I'm using CloneDVD ver 1.3.11.2
Thanks in advance![]()
Emanuele
webmaster - http://www.paolacardullo.net -
The meter does not change as you delete streams,that just the way it works. Every stream you delete will improve video quality. Try to keep only the first audio stream for best video. ac3 streams are 150-500MB's and a DTS stream could be 800MB's. Subtitle streams are small 1-10MB's.
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 05:15 -
How to add and remove audio stream?
By albo23 in forum EditingReplies: 3Last Post: 1st Jan 2009, 09:54 -
Remove subtitle stream from MP4
By Digiface in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 09:41 -
Remove subtitle stream from MKV
By NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 14:59 -
Remove 1 audio stream from VDub?
By Salva Veritate in forum EditingReplies: 1Last Post: 7th Oct 2007, 23:25
