I bought a RCA DRC8000N Recorder about a month ago and have been transfering my Home VHS movies over to DVD. Worked great for all of them (about 50). Today I tried copying a MiniDV tape over to DVD via the front RCA jacks on the recorder and the video played through the recorder and onto the TV I have attached. When I tried recording on a RW+, worked fine. Then I tried a R+ and nothing..coaster..tried another R+ disc and same thing...coaster. It is a brand new spindle of R+ (memorex which is what I've used all along) so I thought maybe I got a bad batch and tried burning a movie off my PC using Nero onto a R+ disc with my NEC DVD Writer Drive. Worked great.
Anyone got any ideas? I'll try another DVD R+ as soon as Walmart opens and I can get more...
When you say "coaster," did you get an error message? Did it record fine but couldn't be played back on a DVD player? Did you finalize the DVD+R?
the DRC8000N just sits there after you hit STOp to end the recording. Then when I can finally get the DCD+R out, nothing will read it. I have since tried another brand of DVD+R and had no problem. I'll be returning the partial spindle to Walmart today and stick to the RCA Recommended brands of which Memorex is not one.
The DVD+Rs ar labeled as 4X but Nero only shows them as 2.4X so my guess is it is a bad batch of discs. I've used Memorex before and had no problem.
Thanks -
Glad to hear that your problem has been solved.
Incidentally, which brand worked for you? -
I used Maxell 4X and Verbatim 2.4X and both have worked with no problems. The memorex are not on RCA's recommended disks so I'll stay away from them.
HDD VS Flash VS miniDV camcorder. Which is better?
By vid83 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Dec 2008, 10:11 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
MiniDV versus non-linear Camcorder
By bowmah in forum Newbie / General discussionsReplies: 9Last Post: 23rd Sep 2008, 02:42 -
Camcorder - DV? MiniDV? DVD? HD? - What?
By MarineMom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 28th Dec 2007, 20:05 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
