I have windows me and I have a dvd image file that is rarred. When I try to unrar it I get an error saying the file is larger than 4 gigs. I have two harddrives, is there anyway I can make a partition or something with NTFS so I can unrar this image and burn it? it's 4.5 gigs it's a PS2 game. thanks
Well, you probably already know ME was one of Microsoft's mistakes, XP or 2000 are major improvements. I don't know of any way you can add a NTFS partition to an existing drive. I would convert one (Or preferably both) of your drives to NTFS if the OS permits it. That 4G limitation is a real problem with todays larger files.
Restore disk image on different operating system
By r3n4ud in forum ComputerReplies: 7Last Post: 1st Sep 2009, 10:44 -
Operating System Suggestions
By radiotaught in forum Newbie / General discussionsReplies: 30Last Post: 3rd Jun 2009, 09:40 -
What's your primary Operating System?
By freebird73717 in forum Newbie / General discussionsReplies: 13Last Post: 26th Aug 2008, 20:26 -
Which Operating System
By Craig Tucker in forum Off topicReplies: 9Last Post: 16th May 2008, 19:52
