I just got the Daewood DVD S151 at Sam's for $40. I bought it mainly
because it's region-free and Macrovision free right out of the box.
My question is about the STOP function. Every other DVD player I've seen
will restart from where you stopped if you stop in the middle of a movie.
But it seems the Daewoo starts from the beginning if you hit STOP and
then PLAY.
Is this correct or is there some setup step I'm missing to override this?
The Daewoo S151 is not macrovision free out of the box and because it uses a Media-Tek chipset there is no way to make macrovision free.
You may be able to record without macrovision effect but when play the tape you will see macrovision at work. -
I haven't really tried recording a DVD to VHS. But I'm running the DVD
through the VHS because my second TV doesn't have audio and video
inputs.
Anyway my question isn't about the Macrovision. It's about why when
I stop a movie and then restart it, the player goes back to the first
instead of starting up from where I stopped.
How to change a Daewoo DSL-19M1WC TV/DVD unit from region 2 to multiregion
By gcatano in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Dec 2011, 02:06 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 07:35 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 10:08 -
Daewoo DVD s150 - Remote Control Model
By alexa19 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Jun 2008, 14:53 -
Owners Manual of Daewoo DVD S151dvd player
By lambuhere1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2007, 07:15
