I am having trouble wiping my CD-RW cd's. Once I have used them I have no software to completly wipt them to there original state. Nero won't accept them once used saying that its not blank?
Anybody know any software etc to use?
Cheers
Adaceg
No, I kept trying to format, oops.
Thank for the help, its sorted now! Cheers again!
Adaceg -
just a note on nero, if you go under the pulldown menu for recorder, there is an option to erase rewritable. It then gives you to options to erase, just the FAT table or the whole disc.
As a side note, its best to erase the whole disc when burning vcd, I've found if you don't chose erase whole disc, that sometimes the dvd player will flip out.
also, if you are doing data files, you can always do a multi-session burn with your cdrw or cdr, you'll be able to add data later. To learn more about the multi-session feature check under the help button, then help topics for nero and type in multisession.
hope this helps out.
TW
PS. on easy cd creator 5, the erase option is under cd, option erase disc.
Need to wipe drive
By neworldman in forum ComputerReplies: 18Last Post: 19th Nov 2011, 12:24 -
Best way to wipe drive
By neworldman in forum ComputerReplies: 6Last Post: 22nd Sep 2011, 16:51 -
Wipe C: drive
By tcory in forum ComputerReplies: 2Last Post: 12th Dec 2010, 21:02 -
Is there a program like DBAN, that can wipe external hard drives clean?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 19th Nov 2008, 02:34 -
Any free software to wipe a hard drive?
By PhoneMatt in forum ComputerReplies: 19Last Post: 5th Mar 2008, 09:35
