Hi
I have just tried to install the latest update for TMPGEnc DVD Author, but i keep on getting messae to insert the cd so it can get a file to uninstall it. If i manually try to uninstall through control pannels i still get the same error. Is there a way yo come arround this as i did not get the cd but just got the download version.
thanks
if you've still got the ORIGINAL installation file that you downloaded and installed, you might try just doing a simple install of it in order to regain the associated uninstallation utility files that you somehow wiped off your computer.
if not, you might try reposting your query in TMPGenc's website forum if no further help is posted on this board.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
Dvd Author Ignoring jump chapter n in title pre commands (no errors)
By FallenAngel10 in forum Authoring (DVD)Replies: 0Last Post: 7th Jul 2007, 16:04
