Thread: TMPGEnc Settings
  1. #1
    TMPGEnc Settings
    Hi all,
    Merry Christmas!!!!!!!!!!!!!!!!
    I just reformatted pc etc and like a bafoon I forgot to note all the enviro settings for TMPGEnc 2.59.47.155
    Can someone please give me the best settings to start with as at the mo I can't do jack with it, lol.
    Is there any alternative software to TMPGEnc to prepare avi/mpg for dvd burn? Looking for something easy like TMPGEnc but maybe less tempremental in the settings department.
    Regards
    Lasher
    Member
    Apr 2002
    The State of Frustration
    Posts
    8,974
    I saw a post by ScottyMac that says to use these:
    It's your environmental settings.
    Do 'em like this...
    DirectShow Multimedia File Reader.......3
    AVI2(OpenDML) File Reader................1
    AVI VFW compatibility Reader.............0
    CyberLink MPEG-2 Decoder.................0
    Microsoft MPEG-1 Decoder.................0
    Wave File Reader..............................0
    BMP/PPM/TGA/JPG File Reader...........-2
    DVD2AVI Project File Reader 1.76+.....-2
    TMPGEnc Project File Reader 2.58......-2
    I am going to try them myself, as I skewed mine trying to fix an encoding problem that turned out to be nothing more than a full disk TMPGEnc was using to store its temp files on.
    Hello.
    Many thx there, seems to be working now on some avi's that kept bombing out. Much appreciated.
    Still after alternative to TMPGEnc, unless it is the best one.
    May Santa furnish you all with something nice from his heavy sack, ho ho ho.
    Lasher
    Member offline's Avatar
    Mondo Caine
    Posts
    5,418
    Check this out.
    http://www.dvdrhelp.com/tools?tool=1#comments
    In your shoes I'd stick with Tmpgenc. There are even some
    nice pre made templates you can download from the tools
    section so you can encode away without concerning yourself
    with the settings.
  1. Settings TMPGEnc to FFMpeg
    By Nologic in forum Video Conversion
    Last Post: 5th Apr 2012, 22:15
  2. TMPGEnc Settings?
    By chronic777 in forum Video Conversion
    Last Post: 27th Jul 2009, 09:14
  3. Help with TMPGEnc 4.0 XPress Settings
    By mister_to_you in forum Video Conversion
    Last Post: 20th Jun 2008, 09:01
  4. TMPGEnc DVD settings
    By Bully9 in forum Authoring (DVD)
    Last Post: 12th Mar 2008, 08:22
  5. Doubt about TMPGEnc Plus' settings
    By alvabass in forum Video Conversion
    Last Post: 13th Jun 2007, 11:52
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
