I want to do the following:
1. Demultiplex a VOB to elementary streams so I get a MPV and a AC3 file.
2. convert a WAV file into AC3 and replace the original AC3 with it.
3. author a DVD and get the videofile to play with the new AC3 file i created.
I've done all this but when i play the authored DVD there's no sound.
I'm using DVD-lab to Demultiplex the file, Ffmpeggui to convert from WAV to AC3, and DVD-lab to author the DVD. I can't use any other authoring software than DVD-lab, as it is the only software that reads my VOB files, all other authoring software has refused.
I'm very new to this, any ideas of what I could be doing wrong that causes the sound to not work?
i don't know, not that i know of at least, unless they were installed automatically along with some other software...
what are they for and where do i find them? -
There are (free) programs specifically for ripping and demuxing DVD *.vobs, such as SmartRipper, DVD2AVI, VOBrator, and VOBedit, to name a few. While DVD-Lab does accept *.vobs the manner it demuxes is designed for its own authoring engine and may or may not produce valid standalone *.ac3 files (or *.m2v, for that matter). As for encoding *.wav to *.ac3, try BeSweet also. On acquiring the *.ac3 file it pays to test first to see if it sounds OK before submitting to the DVD-authoring program. To do this there should be an ac3 dll in your system which automatically gets installed along with a DVD-player program (such as PowerDVD, etc.), or by installing dedicated filters (and associating with, say, Windows media player) that can be found on the tools>audio encoder section of this site.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
just click on AC3 Filter and download and install it.
Chances are that your AC3 file does NOT comply to the DolbyDigital standard...
Try SonicFoundry's (Sony) SoftEncode or Vegas4 to do your DD Certified AC3 Encoding...
Also, do a bit of reading at Dolby's WebSite...
http://www.dolby.com/digital/
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
VirtualdubMod - no ac3 sound in Windows 7 64?
By burcs in forum AudioReplies: 0Last Post: 8th Feb 2010, 17:09 -
no sound on dr. divx ac3
By jwdove in forum DVD RippingReplies: 1Last Post: 25th Jun 2008, 04:07 -
No sound when playing AC3 files...
By GangstaRap in forum AudioReplies: 1Last Post: 9th Feb 2008, 23:21 -
AVI with AC3 - No Sound
By Degradation in forum AudioReplies: 0Last Post: 19th Dec 2007, 16:28
