Removing Macrovision is quite simple.
Go to your local Circuit City and buy a Sima CopyMaster.
Mine cost $35. It is a piece of hardware designed to help boost the signal from a VCR or DVD player. In the process the Macrovision signal is filtered out.
The unit has composite connecters, as well as an S-Video plug, for both in and out.
HAVE YOU TRIED THIS WITH VCR TO PC VIDEO CARD LIKE ATI AIW OR JUST TO VCR I HAVE ALOT OF MOVIES ON VCR BUT AIW WILL NOT CAPTURE DUE TO THAT DAMN MACROVISION BS
There are legal macrovision removers and I believe you can get them for even cheaper than that. Look at Radio Shack. If they don't have it they should be able to order it for you.
thanks adam but ended up picking up the sima its pretty nice but was closer to $50 alls i could find at radio shack was tv/catv attenuator with dial to reduce strengh couldnt see any thing in there cat. either
what would really be nice is a work around fro ati aiw 32 driver macrosh_t driver for mmc 7.1
You could also try (no guaranty!) the "Ati_Demacro" tweak
(divx-digest - forum - Macrovision free.
The best bet is still the Sima box.
How Do I Defeat Macrovision?
By gezvader in forum DVD & Blu-ray PlayersReplies: 12Last Post: 31st Jan 2011, 10:47 -
Macrovision like NONE OTHER
By blacksheepdownunder in forum Capturing and VCRReplies: 17Last Post: 22nd Jul 2010, 04:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 16:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 20:41 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 10:37
