Recieve this unit for christmas. It's a DVHS with TBC and 3DNR. True playback of SVHS, and SVHS ET.
My question, I have figured out how to transfer DVHS recordings to my computer using a program called DVHSTool and the iLink port on the JVC (it's not a true DV out, so it transfer's in MPEG2 TS, not DV).
I want to know if there is a way to use this unit as a on the fly MPEG encoder for VHS tapes and passthru the video to my computer for editing. I can hookup a VCR direct to it and record to DVHS then transfer, but I don't see how this is any different than just bypassing the record phase. The manual is of no help whatsoever.
Thank you in advance any help.
Only way to find out is to test. Post your results too. I'm interested in hearing more.
EDIT: actually can only pull file from DVHS Tapes, not from VHS tapes.
I have successfully pulled a .TS file from the DVHS player to my HD using DVHSTool, a small 10 min. clip. I then open HDTVtoMPEG2 and click the file to open only to have the program immediately crash.
Time to test with a DVHS rip to see if this is a windows problem, a codec problem (in the original rip with DVHSTool) or a user error (most likely).
Will keep updated.
EDIT: I might need a program that comes bundled with a jvc camcorder called Pixela HD Capture Utility 1.0 but i can't find it via my normal means.
JVC SD Card Question
By garyvideo in forum Newbie / General discussionsReplies: 15Last Post: 25th Apr 2012, 15:37 -
JVC HR-S7600U question
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 10:53 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 14:29 -
JVC D-VHS HD Recorder Question
By nlec in forum DVB / IPTVReplies: 0Last Post: 17th Oct 2008, 20:03 -
JVC HM-DH30000u
By robjv1 in forum RestorationReplies: 5Last Post: 14th Mar 2008, 00:57
