HI
I got this HK dvd i bought its a Region Code 2 dvd i extracted the files with DVDDecryptor i removed the IFO RC/RCE/PUO's and set it to region code 1
i then used IFORegionFree to check it and it says Region 1
i then used DVDShrink to get rid of 1gig worth of useless stuff from the dvd
and i then proceed to burn it with nero everything works fine but when i try to play it on my computer the comp still doesnt detect it and when i open it with power dvd it says the cd is unsupported
im new at this so i dont know what to do next if anything.
can you guys suggest anything for me?
the dvd is Infernal Affairs 2 btw
1.) Rip the DVD with DVD Decrypter in FILE MODE and make sure to SELECT ALL FILES
2.) Now process with DVDShrink (assuming this is a dual layer DVD)
Step one removes any and all copy protection including region code stuff.
- John "FulciLives" Coleman
P.S.
You do realize (I hope) that with a single layer original all you need to do is RIP in DVD Decrypter using ISO READ MODE then burn it with DVD Decrypter using ISO WRITE MODE."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
ye i get it
its a dual layer comes out like 6-7 gigs cant remember
FUNNY thing is is that it doesnt work on my computer
but they work on my dvd players :/ anyways thanks
Merry Xmas
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Making a Region 1 Player Region Free. Can't find code.
By KitanaAsh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Feb 2010, 08:28 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34
