Hi,
I have a Matsui 110 DVD and read that it does not take CD-R so I am getting some Memorex CD-RW and was wondering if anybody knows if they would work?
And can they once a VCD have gone on there be wiped and used again!
<font size=-1>[ This Message was edited by: Adam Gunnell on 2001-10-15 09:41:27 ]</font>
Yes they can be used (according to the vendors) thousands of times.
As far as a good price for them Costco carries K-Hypermedia 74 minute CD-RW discs at 10 for under $8, they are a gold layer and I have had no problems what so ever with them.
Or you try the CompUSA 80 minute ones as well -
Usually I burn my (S)VCDs temporarily on CDRW. If I like the end-product I will burn them on CDR. So far, I used my CDRWs several times. No probs so far.
They saved me a lot of money, not using CDRs at once
Greetings
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
