okay so i have a couple of XVID mpeg's.
vcdeasy said they needed autopadding so i started TMPGenc and demuxed then remuxed. vcdeasy allows it.
problem is i need to cut the file to fit on a CDR. i cut it then it needs autopadding again. i demux the first file and remux it. it plays fine.
when it comes to the second file TMPGenc will demux the video but doesnt recognise any audio. this means the autopadding message stays for the second half and there is cuts in sound through the film.
this problem is the same for all files i have tried. it is always the second clip.
all help is appreciated.
thanks in advance.
dave
convert complete file then cut to fit... a local rabbi will advise on precise cutting techniques.. when you pay for advice you can expect a quick reply.
The electronic components of the power part adopted a lot of Rubycons.
Using YAMB to demux audio from MP4 problem...
By takearushfan in forum AudioReplies: 2Last Post: 2nd Feb 2012, 00:44 -
Demux .vob
By Tydus974 in forum DVD RippingReplies: 1Last Post: 15th Jul 2011, 09:09 -
add subtitles using AVI Demux problem
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2010, 02:12 -
Demux Problem
By Felo in forum Video ConversionReplies: 2Last Post: 16th Jun 2008, 02:42 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 18:07
