Authoring & Sync Problems:
Hardware, Software:
ATI All In Wonder Radeon Video Card
Hauppage PVR 250 PCI Capture card
TDK Indi 4X Multi Format DVD Burner
Easy CD/DVD Creator 6 Platinum
Ulead Video Studio 7
DVD Movie Factory 2
TMPENC DVD Author
TMPENC Plus 2.5
I'm in the process of converting my analog concert videotapes into DVD's. I capture the video at "standard" DVD quality with the PVR 250 card. No problems there > fine quality video & audio is in sync.
I authored & burned a dvd with Ulead DVD Movie Factory 2 which was in sync. However I couldn't get the menu's the way I wanted them so I used TMPENC DVD Author > I was able to get menu's the way I wanted them > BUT the audio is NOT in sync!!. I then tried de-multiplexing & re-multiplexing the original file with TMPENC PLUS > resulting file was out of sync. Is there some settings that I'm missing with TMPENC? I've seen many posts that recommends this software over many other programs. Do I need to change priorities of some of the plugins? I'd be happy to pay for this program if I can get it working right.
At this early stage of creating dvd's I want to create a concert dvd that plays automatically & has these menu options:
"Play Concert" & another "Select Songs/tracks" which when selected lists my songs. I couldn't get that right with DMF 2 but could with TMPENC DVD Author but that has a sync problem.
I've seen various posts with some people using up to a half dozen programs to accomplish what I'm trying to do. I would like to keep this as simple as possible. What am I missing??? Any tips or links that will solve these problems will be greatly appreciated.
Happy Holidays!!
