Is it possible to normalize the audio portion of a clip within VirtualDub or it's variants? Would really be convenient if I could direct stream the video and full process normalize the audio!
I have way too many clips requiring normalizing to even begin contemplating demuxing/normalizing/muxing. V'Dubs volume adjust would also require sampling each clips level as they are all different...another time prohibitive option.
Regards,
Golem
I may have an idea. Will alll the vidoe clips be part of one or several videos when you are done?
Hello. -
teegee420 - Thanks, pretty much what I was believing.
tommyknocker - Unfortunately...No. All these clips (over 600) are completely different and will remain independent.
Btw, doing a search over at Doom9's forum I see where about a year ago someone started a thread asking about this option and even hinting that they may write code or a filter to perform this within V'Dub. Sadly though I can find no evidence that they carried through.
Best Regards,
Golem -
Oh well. I was thinking, there is a normalize filter in AviSynth, which can be run in Virtual Dub. What do you think?
Hello. -
Hmmm, that just may be an option as it does reduce the workload quite a bit as opposed to the demuxing/normalizing/muxing method!
With egg on my face I will admitt that all these clips were encoding using AviSynth/VirtualDubMod...all the while overlooking the option of normalizing in AviSynth!About two weeks ago I finally smartened up, realized my idocy, and began normalizing in AviSynth. Unfortunately I've accumulated a backlog of the non-normalized clip that still need processing. Guess I had better get to work!
Very much appreciate your input.
Golem
Mini Guide: Normalizing Audio for Multiple AVI files
By Soopafresh in forum AudioReplies: 456Last Post: 9th Dec 2016, 22:26 -
Audio Normalizing
By dvddemon in forum AudioReplies: 7Last Post: 26th Sep 2011, 21:02 -
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
Normalizing audio help
By 1031982 in forum AudioReplies: 10Last Post: 23rd Jun 2009, 22:42 -
Normalizing Audio
By evilbubbles in forum AudioReplies: 2Last Post: 7th Dec 2008, 15:04
