can I capture audio from my line in in vitrual dub or do I have to plug it into my microphone to record audio??
You should probably use the line in input unless you're using a microphone for 2 reasons. First, most microphone ports are mono. Second, microphone ports usually use a +20db boost, which will clip most other audio sources such as cd, tape, and dvd players.
Capturing audio
By kschwi in forum AudioReplies: 2Last Post: 25th Apr 2012, 12:13 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum Capturing and VCRReplies: 3Last Post: 29th May 2008, 08:22 -
RE-Capturing Audio
By Casper_H in forum Capturing and VCRReplies: 1Last Post: 16th Apr 2008, 10:23 -
capturing dv audio only
By Driber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 25th Feb 2008, 10:36 -
Help capturing line in audio
By djain91 in forum AudioReplies: 1Last Post: 22nd Nov 2007, 17:58
