I´m trying to burn data to a cd-r but Nero sais it doesent work because its not a dvd disc in the burner. How do I make Nero understand that I want to burn on a cd-r. I have a dvd burner.
If you using Nero(6) StartSmart switch from dvd to cd on the top right corner. If you using Nero Burning Rom just select your burner at the top. I think also just before the burning you have to select which burner you want to use.
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 04:28 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 20:21
