Hi
I hate to use my firstpost to ask for help but....
I have a Sony Vaio:
2.54 Ghz
512 MB Ram
120 GB Hard Drive
and I got a
ATI All IN Wonder VE PCI card it came with Pinnacle Studio 8
I can only capture at 352x240 or 480x480 without dropping frames is there anything i can do about this? should i use a different capture program? do i need more ram?
any help or advice is greatly appreciated.
A couple of things I may suggest. First, when capturing, capture only. Shut down every unnecessary application when doing it.
Get another 7200 RPM hard drive, and capture only to it. If you know how to partition, put your system files on a C: partition, and capture to a separate drive altogether.Hello. -
first of all thanks for the advice.
But i already close everything down including virus protection and my capture files are already all on a seperate partition than system and program files.
Issues with capyuring HD video
By RockWood610 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Apr 2008, 23:53
