  1. I downloaded an AVI file of 702mb from Kazaa(was an incomplete download). But the same does not play on any media players - WMP, BSplayer, QT, etc. Tried changing the file xtensions, to no avail.
    I had seen previews of the same file while being downloaded, and it worked fine. What do I do?
  2. Member Treebeard's Avatar
    Aug 2002
    if it is an unfinished download then you wont play it until you rebuild the index. you also need to make sure you have the correct codecs
    use divfix to rebuild index and watch.
