New card can watch ok but cant capture audio with the video.
Any advice please.
Results 1 to 9 of 9
Yeah Baby!
Check the audio source/recording options within your software. Most likely needs to set to Line-In.
have looked on the aver softwaRE and virtudub cant find a line in option.
For your info I can get sound when watching tv just cant get it to capture with sound.
Thanks for your help so far.Yeah Baby! -
VirtualDub - Capture AVI - Capture - Settings - check Capture Audio check box.
VirtualDub - Capture AVI - Audio - Windows Mixer - check box for your audio input source.
Good luck -
Thanks, was using an old version of virtudub, so I didn't have that option.
Downloaded latest version and now it works!
Hooray!
Thanks Guys & Merry Christmas.Yeah Baby! -
Just burnt the resulting image to disc:
15.5gig AVI file converted to Mpeg2 1.6gig!!!
Put into Spruce up for image & burnt with dycrypter.
THE QUALITY ROCKS!
I am very impressed with my first capture, there is some minor audio synch issues but as soon as the audio runs out it looks like it has been brought back in (perhaps a feature of virtudub?).
Anyway long message short: ME VERY HAPPY.
Yeah Baby! -
Some audio sync problems can be traced back to frame rate. Check your AVI master copys frame rate with a program like VirtualDub - File INformation to make sure it's exactly right. (like NTSC 29.970). MPEG2 conversion programs will output the exact frame rate required for DVD and if your AVI isn't perfect the audio can/will suffer.
I"ve also seen sync problems being something as simple as the audio file is like a 1/2 second shorter than the video. Converting such an AVI will surly have sync problems. This can be corrected easily once you know what's going on.
ANyway... Congrads!!! and good luck.
So how do I use VirtualDub to capture from the AverTV HD DVR?
By Asterra in forum Capturing and VCRReplies: 55Last Post: 16th Feb 2014, 00:42 -
DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTV
By asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 10:22 -
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 21:16 -
Best Capture Card Under $150?? (AVerTV CaptureHD??)
By jenna12 in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2010, 13:38 -
AverTV Studio capture problems at 640x480
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 3rd Aug 2007, 06:34
