Results 1 to 14 of 14
  1. When my original DVDs get too many thumbprints on them, I wash them with detergent and wipe them dry with a tissue paper. Is this bad?
    If not, can I do this with CDRs and DVDRs?
    Apr 2002
    The State of Frustration
    I woukl invest a couple bucks on a disc cleaner. The item was made specifically for cleaning disks. I don't know about the detergent/tissue paper process, but why take chances?
    Hello.
  3. I just use a 70% solution of Isopropyl Alcohol/water and tissue paper.
  4. Member steptoe's Avatar
    errr, I normally use furniture polish, the spray on type that is used for general dusting, and a duster thats been washed a few times so its nice 'n' soft
    Mr. Sheen or similiar product
    Works, and its cheap, as yet, no damage done, and does a very good job of removing greasy prints and other nasties that get attached to the surface
  5. Member wulf109's Avatar
    Jul 2002
    Whether you use glass cleaner or alcohol I find it's very important to buff the disk with a lens cleaning cloth to remove any "cloudiness" left by the cleaning method.
    Dec 2002
    Never tissue paper, how do you get the dust of?
    Dry clean soft all cotton cloth works fine. Old cloth diapers are good, or an old flannel shirt.
    Alchohal can affect the glue at the edges of your disk.
    Plain water works fine.
    Window cleaner (ammonia based) can work okay, don't overdo it.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  7. or search for lint-free cloths ... they are used in criminal forensic investigations and are gtd not to leave any lint(cloth fibres),, they are actually cut by laser beam into small squares.
  8. Lemon scented Pledge works the best, along with at soft, lintfree cotton cloth. The wax in the Pledge fills in any small scratches, makes all my disks (even the beatup ones) play perfectly
    Oct 2003
    Ahhh yes, Pledge. Works wonders on plastic lens eye-glasses as well.
    In the world of audio/video, 2 + 2 is sometimes 63.
  10. Video Restorer lordsmurf's Avatar
    I have some Teflon fiber, as you seem to suggest, but it scratches.
  11. i use the same stuff i use to clean my glasses
  12. I breathe out hard on them and use my shirt. I find clean shirts work best. Water + shirt works for me too.
    "As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
  13. Originally Posted by DaveS
    This is why this site needs a quotes page.
    I use a "lens cleaning pen" Basically it's a microfiber cleaning pad attached to a pen that has a cap with what I believe is powdered graphite in it. When it gets dirty just put in the cap and twist. It works wonders. I've used it to remove pop residue and just plain greasy fingerprints.
    If it's a rental dvd that I could care less about I just use plain old dishwashing liquid, rinse and buff with a shirt.
  14. I use STEEL WOOL. Works For Me. hehehehehehehehe
