i recently bought a sony dvdrw dru-510a. i wanna burn the .cue and .bin file to cdr and dvdr. but i cant.
nero cant detect my dvdrw.
so how and what should i do.
pls help.
i am desperately in need of help.
thanx in advance.
I had a bad time with a the same burner and was back and forwards to Sony support. This is a sensitive burner (I think they all are).
The media is the key. Use TDK -r or RW. Shintaro or Princo (same as shintaro) I am sure there are others that work but I stick to these. -
also make sure you have the latest firmware on you burner (I believe they are up to "d". Hope all this helps. Merry Xmas.
but i need to know how to burn it out.
since i can no longer use nero. and the file is .cue and .bin.
anyway to make the write to burn to the software i wan? -
Upgrade to a newer version of nero to recognize your burner.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 13:18 -
Urgent Question Sony CCD-TRV438E Hi-8 Analog Camcorder
By Shaga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 14:32 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 21:33 -
Compatible DVDs with Sony DVDRW DRU-700A
By dzachau in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 15:25 -
Samsung DVDRW Drive Won't Eject
By 888888 in forum DVD & Blu-ray WritersReplies: 4Last Post: 5th Nov 2007, 20:27
