I was wondering what the purpose for these tools is....
VCDxBuild
VCDxRip
I just don't understand what they are for....
anyone who knows please tell me... thanks.
It's in the documentation, either as html or pdf, if you go to http://www.vcdimager.org or go to Vitualis' site at http://www.michaeltam.com.
In a nutshell...
vcdxrip -- it is a tool that disassembles a disc image of a SVCD or VCD into the component media files (and other files if they exist in the filesystem) as well as creates an XML descriptor file/script.
vcdxbuild -- this is the reverse of the above. It takes an XML descriptor file and the associated media files to build a disc image of a S/VCD.
Both are tools of VCDImager -- one of the best VCD authoring systems in existence. They are command console tools -- so under windows, it is probably easier to use a GUI like VCDEasy or VCDImager Tools GUI.
The image format used is the CUE/BIN image format or the CDRDAO TOC format.
For more info: as per Cornucopia -- see the VCDimager manual or have a look at my site: http://www.michaeltam.com
Regards.Michael Tam
w: Morsels of Evidence
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 13:50 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 09:04 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 15:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 07:40 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 03:39
