  1. I was trying to do a one to one copy with both programs and then something that says like cycle redundency came up and it came out like an error. I was wondering how i could by pass this or just make a one to one copy some other way with a different freeware program. Thank you for your time.
  2. Could you give some more info. Most probably you have some kind of problem with the disk you are trying to copy. Still need more info.
  3. When it gets to 90% and its always 90% percent the reading rate goes down and after like 356 tries, a window that says I/0 Error! In this similar format
    I/O Error!
    Device:[1:0:0]
    ScsiStatus: 0x02
    Interpretation: Check COndition
    CDb: 2a 00 ff ff ff 6a 00 00 20 00
    Interpretation: Write (10) - Sectors: 4294967146-429467177
    Sense Area: 70 00 05 00 00 00 00 0A 00 00 00 00 2c 00 00 00 00 00
    Interpretation: Comman Sequence Error
    It says something like that i also tried dvd shrink and sometimes it gets to 96 and sometimes it gets to 85 but never finishes because an error. Thank you for your time
  4. I had the same problem. I found out that it's due to bad media.
    I kept getting the same error burning with dvd decrytper and nero. For me the error kept coming up at 1% of the burn, so what i did was:
    1. chose to burn at 1x speed
    2. kept going through the stack till there was one that would actually burn.
    Needless to say, I will not be buying those dvd r- disks again.
  5. The problem was just reading the disk. Yea, i think the dvd original might be a little bad or something. After i tried a lot of times over and over, it actually worked and i burned that. Well, anyways thanks for your reply and have a nice holiday weekend.
