Im converting SVCD to DVD and when I use the program SVCDTODVD the dvd is fine half way through the movie but when I have two vcd files the second one has audio problems. The audio doesn't match the lip movement in the movie. Another problem ... I can't use rewind, fast forward, pause or anything like that when I play them in my dvd player ...
Anthony
I had the same problem only i was using tmpgenc to merge and cut the files.I d/loaded easy video joiner and am now encoding with mainconcept mpeg encoding and everything is stoping in sinc.It worked for me anyway.
RM in SVCDTODVD
By Hansi123 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Aug 2007, 09:31
