I've read everything I could and downloaded way too much stuff and still unable to do it. This is what I have and hope someone can tell me what I'm missing. I've used TMPGEnc before but one thing I noticed was that audio stated "Unknown (TAG 2000)" if that means anything. Virtual Dub doesn't seem to be able to convert this. I'm still a newbie at this.
File
700 MB (700 MB), duration: 1:00:56, type: AVI, 1 audio stream(s), quality: 69 %
Video
505 MB, 1159 Kbps, 23.976 fps, 640*272 (2.21:1), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported
Audio
195 MB, 448 Kbps, 48000 Hz, 5 channels, 0x2000 = AC3 DVM, Supported
It's the AC3 audio that's causing your problem. You can use Virtualdub to strip it off then use Headac3 to convert it to a proper WAV with 44,100 audio.
There's guides for all of what I just described right on this site, or on Doom9.
http://www.doom9.org/index.html?/audio-guides.htm -
VirtualDub can convert this file, but not to VCD. Just load the file and select 'Save Wav'. Take the Wav file and your video file back to TMPGenc.
If all else fails, setup VirtualDub to save the video and audio in AVI format with Huffy compression, then take that file back to TMPGenc for conversion.
It's 23.976 fps!
Good luck -
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 08:09 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 09:18
