  1. Ok people round two for problems. And this one has me just about to scream. I have now built about 5 computers, and installed Windows about 40 times, installed every kind of component. I have burned CD's, and DVD's and after all that am left here with a small problem that I cant get around.
    I build a new system, and its got a new hard drive. So boot up with Windows CD in the computer, it starts the installation of files needed. Then it reboots after its done, heres the problem. Rather than keep going with installing Windows, it boots from the CD and then starts to try to install the Installation files again. Its stuck in a loop, and I just cant get out of it. I tried to take out the cd, but it wont boot. I tried to change the boot sequence, and nothing works.
    So I had a drive that I was just going to Ghost to it, but my dad was bored and at home and tried to fix the problem and has now ruined the drive I was going to use as a ghost.
    Anyone have any idea on what I am doing wrong?
    "Sleep-
    Those little slices of Death;
    How I loath them."
  2. did u change the boot sequence at the reboot or before u started???
  3. Check your Bios boot settings. Could be that it's set to only boot from CD.
    2 DVD, or not 2 DVD, that is the question.
