  1. Is it possible to remove the sub titles from a VCD?
    Thanks.
  2. Member adam's Avatar
    Sep 2000
    No its not. If the subs are below the picture than you could just re-encode it and add black bars over it but if its over the picture theres really nothing you can do.
    You can use the logoaway filter in virtual dub to blur out the subs but they will still be noticable since the subs take up so large an area. Instead of subs you will get a huge blurry rectangle so its really not worth it.
  3. Cheers Adam. I'm on holiday in China at the moment and bought a couple of films. Probably won't buy any more if sub titles cannot be romoved.
    Cheers
    Sean
