Hi Folks
I have a Hauppauge Win DVB-s and I’m recording via DVB software ( digital TV) directly Mpeg2 format.
When I record some channels ( most of them ) they are recorded as mpeg2 but with Resolution 544 x 576 and when I want to make DVD from those recorded file it will go through rendering which will take ages ….
The strange thing some other specific channels with the same setting it is recording Resolution 720 x 576 which I don’t have any problem with creating DVD Through Software’s like ( Ulead or Vegas ) dos not re-render the video files if it was Resolution 720 x 576
In both cases Audio will be re-rendered which not big deal because will not take too much time .
Do you have any idea how to force those channels to record with Resolution 720 x 576 or Do you know any fast and easy software to convert the Resolution 544 x 576 to Resolution 720 x 576?
I tried several other Software’s for recording those channels , I’m not sure because I don’t have deep background but it is look like the sender is sending with Resolution 544 x 576
Thanks for you help
