    Dec 2002
    what type of movie file do i need to put into the menu program in tmpgenc authour so the sound will play as well as the movie?????
    Dec 2002
    done a bit of searching through the forum and found this "Your background video file should have muxed video/audio for this to work." how can i do this ???
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Muxed audio/video just means that you have a file with both audio and video. I would assume that TMPGEnc DVD Author would accept MPEG-1 with perhaps an animation or sequence or still frame that will act as a visual background while the audio plays. I know there is a looping setting as well.
    If in doubt, Google it.
    Dec 2002
    so what type of audio file do i need to put in the audio selection on tmpgen then ???
  5. mp2 or pcm. Given certain conditions, ac3.
    For more info, open TDA; select options>help>specifications. Also read associated (asterisked) helpfile audio footnotes.
    If your input file is already muxed with acceptable video/audio filetypes, it will be automatically entered into both video/audo TDA input windows when using it's "add file" function...
    Rewriteable disks are _really_ cheap whilst in learning curves..
  6. Member daamon's Avatar
    Melbourne, Oz
    Valid audio formats for DVD's (mpg2 video at least - I've not bothered with mpg1 as quality isn't worth it when I can do mpg2 -> DVD) are AC3 & PCM (also known as WAV). Some DVD playes (particularly like in Europe) may also accept mp2 audio.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  7. Member djmattyb's Avatar
    Dec 2001
    Seattle
    What I do is take the picture I want and the song I want, put them in Adobe Premiere and output it to a DVD compliant mpg2 video. That video is what I load as the background in TMPGENc DVD Author. You might be able to do this with TMPGEnc as well using the 'Tools', but I haven't tried it.
    dj matty b
