I am bringing in 8mm tapes via my camcoder which has Analog/Digital passthrough capabiliites. Capturing in Sonic MyDVD4 - works ok - but it creates one big chapter - the only way I see to create chapter points is to either set there and manually hit the space bar to create a chapter point or set a timer to create chapter points. That doesn't work for me because the chapter point won't be exactly where I want it. So How can I do this ?
Should I pull the raw digital (avi) data into another package and create the clips or chapter points - if so what package would do that. Then the question - If I create these break points in another package - will Sonic's MyDVD4 recognize the chapter points when I pull them into MyDVD in the form of edited AVI files ?
And Lastly, will this still be a problem when I start doing regular MiniDV tapes from my cam instead of A/D passthrough ?Or will it still create one big chapter point without user intervention ?
Results 1 to 1 of 1
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 20:42 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
